2006 Dodge Caravan - Dome lights
I need help with my Map / dome lights that will not work on my 2006 caravan. I have tried new bulbs but still not working. Any ideas appreciated.
It’s likely a fuse. The owners manual should have the info as to which fuse.
I had a friend that bought a used Caravan that his kids kept leaving the sliding door not quite closed and killing the battery. That problem was solved when I showed him how to shut off all the door and interior lights. On his it was a vertical slide switch the dimmed the dash lights. slide it all the way up and it turned on the dome lights , all the way down it turned off the door, dome and dash.
