2006 chrysler 300 c hemi car not charging put two alternator in still not charging
Is your battery any good?
How old is the battery?
Your car almost certainly has either mega-fuses or fusible links for the charging system . . . are they good?
If the fusible link and/or mega-fuse for the charging system is blown, the alternator won’t do its job
There is also the possibility the alternators you’re putting in are somehow defective
But I would check the battery and those fuses first
