I replaced three steel rusted brake lines on the front of my 2006 Cadillac sts. Got new lines put them on filled the system up with fluid but cant get any brake pedal pressure >help
You need a scan tool to position valves in the ABS module to their proper position in order to bleed the brakes.
How are you trying to bleed the brakes?
2-man method?
Vacuum?
Gravity?
Diaphragm brake bleeder?
