The car very badly starts shaking the engine beat smoke with the exhaust spark plug in the third cylinder was wet from the petrol ignition coils are fine what caused it one with a Volvo 2.0 60 T 2005 car why the cylinder flows so much petrol? I would also like to add that I changed the pcv hose before replacing the car drove well
a bad fuel injector could cause excessive fuel in that cylinder.
Swap the fuel injector from #3 with another cylinder. If the misfire moves with the injector, replace the injector. If the misfire stays with #3, do a wet and dry compression check to determine if rings or valves are causing low compression.
Hi I’ll do it for now, thank you
Dne st 19. led 2022 7:28 uživatel oldtimer 11 via Car Talk Community <cartalk@discoursemail.com> napsal:
