2005 Peugeot 405 - Leaking fuel
my puegeot 206 is leaking fuel, on top of the fuel tank i noticed the second pipe or tude(green) is folded.
I think that the obvious solution is to drop the tank and replace the damaged gas lines.
If you can’t do this yourself, then you will have to go to a mechanic’s shop.
And get it fixed now, that’s a fire hazard.
thank you for your response.
