2005 Infiniti FX35 - Mirror broken
power side mirror does not go up
Check the fuse. Not sure which fuse it is? That info is likely in the “fuse” section of your owner’s manual.
These mirrors commonly get stuck from not being moved very often. Use your hand to force it up and down. (It will make a grinding noise, no worries, it doesn’t hurt the mirror.) Try it again.
Maybe a bad switch… the “up” contact.
