2005 Honda CR-V rotor diameter
Does anyone know where I can find the inside diameter for the front rotor in a 2005 CRV?
I see two different widths, one of 151.5 mm here, and one of 151.8 here…
Thanks, Brendan
Why would you need this number? Either the rotor fits or it doesn’t. Both claim to fit your car so both should fit.
Your header says “rotor diameter”, but in the post it says “width” and the dimension seems to be the inside diameter of the rotor which only has to clear the hub. If the 151.5 will clear the hub, the 151.8 certainly will.
