2005 ford focus 2.0 dohc crank but no go flooded cylinders, changed tps, fuel pressure regulator sensor twice dunno whats wrong anyone know
Have you tried flooring the gas pedal? This shuts off the injectors.
Does it run ok once it starts? And are you sure the problem is flooding? If so, gas must be leaking into the cylinders when the engine is turned off. The most likely cause is leaky fuel injectors. A fuel pressure hold test would confirm.
Do you have spark?
