I have to put a clutch in my 2005 dodge neon any tips on what to look out for or ways to make it easier
No, nothing special if you have done this sort of work before.
I suppose you know you must mark the clutch cover and flywheel to maintain their same relative positions when installing the clutch assembly. Avoid touching the clutch disc with oily or dirty hands. You will need a clutch disc aligning tool. When finishing up, tighten the bolts in a crisscross pattern to avoid distorting the clutch cover.
And if you post back, find the Caps Lock button on your keyboard.
