My locks stop working. I found one solution that says remove the fuse that contros it, wait 5 seconds and then replace it. The soluation works, but form timt to time it stops working again. Is there a more perminate solution.
“My locks stop working”.
When and how?
Interior switches, remote?
Both, it seemed to happen when the weather changed, hot to cold, but I don’t really know if it just happens randomly, with no real reason
Since a “power fail reset” seems to make things work again there may be an electronic module used to control the locks. If that is the case you may need to replace that module.
