VSC Track and Check Engine icons
go to a mechanic
Auto parts stores in most places will read the code or codes that are setting the check-engine light for free. Give them to us when you have them.
Many cars disable traction and stability control when the check-engine light is on, so don’t worry about that part for now.
The VSC warning light is probably a result of whatever’s turning on the CEL. For the stability control to work the engine performance has to be spot on. Once the original problem is solved the VSC warning should go out by itself. As posted above the next step is to figure out what engine diagnostic codes are being produced.
