2004 Nissan Quest Starting issues
Car stalls at odd times. Put in nut. and would restart. Now I have to wait an hour or more before it will start. Changed crank sensor, fuel pump fuse. When it wont’t start, fuel pump is not running?
I’ll bite. What kind of nut did you put in?
CSA
:palm_tree::sunglasses::palm_tree:
Maybe they mean neut., as in neutral? Sounds like a fuel pump relay issue to me.
I can’t answer whether or not your fuel pump is running from out here on the internet. You will have to tell us if it s running or not.
