When I turn left I hear a jungling, metalic sound in right front end.Only when I turn left not turning right. And when I hit a bump I hear that sound. When I drive into a drive way while turning left it clangs-jingles. I checked everything up front myself can’t find anything lose.
 Whats the Problem?
 Merle Swain
 Boise Idaho
 208-866-0215
The noise might be coming from a loose heat shield above the intermediate shaft out of the transaxle.
I checked the Heat shield and it is not lose, can’t find anything around in that area that’s lose. The metal shield on the wheel sort of sounds like the noise when I tap it on it but it not lose either.
Merle
I checked the Heat shield and it is not loose, can’t find anything around in that area that’s loose. The metal shield on the wheel sort of sounds like the noise when I tap it on it but it not loose either.
I think it might be the brake housing just a guess. Does anyone have any other ideas…
Anything would help.
Merle
