2004 Dodge Stratus R/T: Smelly inside due to leaves trapped in A/C Condensate Drip Pan
I have a partially clogged A/C condensate drip pan. I’ve already had the dealer try to clear out the blockage but the problem is that somehow I got a bunch of leaves stuck in the pan. Now they’ve been slowly rotting in there for over a year and it smells like a pile of wet leaves in my car. Plus there is water sloshing around in there since it can’t get out fast enough. Apparently you need to remove the entire dash to get at the condensate drip pan. Any thoughts?
Yea, remove the dash or learn to like the earthy smell of the rain forest. You need to fix the cause not try and cover it up. Nothing is going to work for long except the real leaning it needs.
