Where is the water pump located in the 6 cylinder model? Is it on the right, left or top of the motor. I had a leak of anti-freeze around the connection to the motor, and the pink fluid showed up on the bottom of the lower left head gasket. Could the leak cause this 1/8" line of pink deposit on the head gasket?
Antann
