2003 nissan sentra
hard to start on cold mornings. crank and crank and when check spark plugs, they are drenched with fuel. tried another fuel pump and didn’t work. help me
If the sparkplugs were drenched with fuel, the engine was getting fuel, so the fuel pump was working and didn’t require replacement. You need to check if there’s spark at the sparkplugs when trying to start the engine.
along with checking the spark check the spark plug gap sounds like they might be out of gap a little
