i have a 2004 ford ranger it will stop running all of sudden going down the road.
I presume that by “Stop”, you mean that the engine shuts off.
This could be a ignition module, or a crankshaft position module that is faulty.
Sometimes this is heat related and the module shuts down.
Yosemite
When the engine stops try checking the fuel pressure at the schrader valve on the fuel manifold it looks like a tire valve and you can press the center valve pin to see if there is any fuel pressure. This could help in determining if there is a fuel or electrical problem. My experience was a bad fuel pump when the engine died.
