engine shuts of after warmed up. no eml codes stored. car will usualy start back up but will stall again few mins later. any advice
I am not sure if this is the reason for your problem, but I will pass this recall on.
A bad crankshaft position sensor can cause that.
As weekend warrior says that was a possibility but I’d imagine it would have shown up before now, all the ones sold through us back in the day were done within a couple of months. If you’re getting no codes it may a blocked carbon canister for the fuel system, I’ve also seen the DME go bad and hence no code stored
