2002 Lexus ES 300 P1350 code
showing code p1350. three lights remain on. track light,vsc and check engine. can you tell me what iswrong/
That is an error code for the variable valve timing system, bank 2. Several things can cause the code like dirty oil or a broken valve actuator. A good mechanic can work through to find which is actually causing the error.
That code likely will set the traction and vsc lights at the same time so fix that and the others will go away.
Thank you very much.
