2002 Lexus ES300 VSC and TRAC Off lights on
This is a new phenomenon for me and from what I have read it could be the emissions system, gas cap or Catalytic. Clearing the codes only brings the lights back on when I put the car in drive or reverse. I know I can replace the gas cap (cheap) Replace the catalytic ( more expensive - since the exhaust has a rupture in the braid) and have the emissions sensor replaced (marginal cost)…Has anyone dealt with and achieved success in fixing this issue?
" it could be the emissions system, gas cap or Catalytic."
…or, it could be one of about a hundred other possibilities.
Even though you didn’t mention it, I am going to assume that the Check Engine Light is lit-up, in addition to the VSC & TRAC lights. What you need to do is to find out which diagnostic trouble code(s) have been stored by the OBD system.
If you go to Auto Zone, Advance Auto, O’Reilly, or (possibly) Napa, you can have the codes read, gratis. Then, you can come back to this thread to report the specific codes and get specific advice, based on those codes. They will be in a format similar to “P0123”.
+1 to what @VDCdriver said
When engine light is lit it automatically disables traction control and ABS. This is clearly spelled out in your owners manual.
Don’t assume cause it’s not. I didn’t mention it because it’s not the case. Will check for codes though I am looking for someone who has encountered and fixed this issue before…
No one knows what then issue is. You need to get the codes read. There could be several HUNDRED possibilities. Pick one.
Highly doubt there are hundreds…a good mechanic, who has found this issue and fixed it, can offer more than codes to look up.
Not without knowing what the code is. And YES it could be HUNDREDS. Do a google search of ODB-II codes.
Again I say, if you had done a repair like this you would know what the remedy is. Just for you Mike I will get a code and then you can narrow it to 500 k?
Nope. Those lights can come on for several reasons. Get the codes read.
This is one of those cases where the OP isn’t aware of what he doesn’t know.
EXACTLY.
Jeff - no one is trying bust your b@lls. We actually are trying to help.
When the engine light is light it’s telling you that there’s a problem. It does NOT tell what the problem. The error code is stored in the ECU. You need someone to hook up a scanner to tell WHAT the problem is. It could be the EVAP system or O2 sensor or map sensor or HUNDREDS of other codes. Have someone read the code and post back what the code is.
Here you go Jeff, still think there couldn’t be hundreds of causes. And this isn’t even all of them.
Sorry to everyone else but it had to be done. We obviously have a dis-believer here.
• P0001 Fuel Volume Regulator Control Circuit/Open
• P0002 Fuel Volume Regulator Control Circuit Range/Performance
• P0003 Fuel Volume Regulator Control Circuit Low
• P0004 Fuel Volume Regulator Control Circuit High
• P0005 Fuel Shutoff Valve “A” Control Circuit/Open
• P0006 Fuel Shutoff Valve “A” Control Circuit Low
• P0007 Fuel Shutoff Valve “A” Control Circuit High
• P0008 Engine Positions System Performance Bank 1
• P0009 Engine Position System Performance Bank 2
• P0010 “A” Camshaft Position Actuator Circuit (Bank 1)
• P0011 “A” Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
• P0012 “A” Camshaft Position - Timing Over-Retarded (Bank 1)
• P0013 “B” Camshaft Position - Actuator Circuit (Bank 1)
• P0014 “B” Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See
• P0015 “B” Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
• P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
• P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
• P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
• P0019 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
• P0020 “A” Camshaft Position Actuator Circuit (Bank 2)
• P0021 “A” Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
• P0022 “A” Camshaft Position - Timing Over-Retarded (Bank 2)
• P0023 “B” Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
• P0024 “B” Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See
• P0025 “B” Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
• P0026 Intake Valve Control Solenoid Circuit Range/Performance Bank 1
• P0027 Exhaust Valve Control solenoid Circuit Range/Performance Bank 1
• P0028 Intake valve Control Solenoid Circuit Range/Performance Bank 2
• P0029 Exhaust Valve Control Solenoid Circuit Range/Performance Bank 2
• P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
• P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
• P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
• P0033 Turbo Charger Bypass Valve Control Circuit
• P0034 Turbo Charger Bypass Valve Control Circuit Low
• P0035 Turbo Charger Bypass Valve Control Circuit High
• P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
• P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
• P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
• P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
• P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
• P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
• P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
• P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
• P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
• P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
• P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
• P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
• P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
• P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
• P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
• P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
• P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
• P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
• P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
• P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
• P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
• P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
• P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
• P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
• P0065 Air Assisted Injector Control Range/Performance
• P0066 Air Assisted Injector Control Circuit or Circuit Low
• P0067 Air Assisted Injector Control Circuit High
• P0068 MAP/MAF - Throttle Position Correlation
• P0069 Manifold Absolute Pressure - Barometric Pressure Correlation
• P0070 Ambient Air Temperature Sensor Circuit
• P0071 Ambient Air Temperature Sensor Range/Performance
• P0072 Ambient Air Temperature Sensor Circuit Low Input
• P0073 Ambient Air Temperature Sensor Circuit High Input
• P0074 Ambient Air Temperature Sensor Circuit Intermittent
• P0075 Intake Valve Control Solenoid Circuit (Bank 1)
• P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
• P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
• P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
• P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
• P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
• P0081 Intake valve Control Solenoid Circuit (Bank 2)
• P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
• P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
• P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
• P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
• P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
• P0087 Fuel Rail/System Pressure - Too Low
• P0088 Fuel Rail/System Pressure - Too High
• P0089 Fuel Pressure Regulator 1 Performance
• P0090 Fuel Pressure Regulator 1 Control Circuit
• P0091 Fuel Pressure Regulator 1 Control Circuit Low
• P0092 Fuel Pressure Regulator 1 Control Circuit High
• P0093 Fuel System Leak Detected - Large Leak
• P0094 Fuel System Leak Detected - Small Leak
• P0095 Intake Air Temperature Sensor 2 Circuit
• P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
• P0097 Intake Air Temperature Sensor 2 Circuit Low
• P0098 Intake Air Temperature Sensor 2 Circuit High
• P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
• P0100 Mass or Volume Air Flow Circuit Malfunction
• P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
• P0102 Mass or Volume Air Flow Circuit Low Input
• P0103 Mass or Volume Air Flow Circuit High Input
• P0104 Mass or Volume Air Flow Circuit Intermittent
• P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
• P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
• P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
• P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
• P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
• P0110 Intake Air Temperature Circuit Malfunction
• P0111 Intake Air Temperature Circuit Range/Performance Problem
• P0112 Intake Air Temperature Circuit Low Input
• P0113 Intake Air Temperature Circuit High Input
• P0114 Intake Air Temperature Circuit Intermittent
• P0115 Engine Coolant Temperature Circuit Malfunction
• P0116 Engine Coolant Temperature Circuit Range/Performance Problem
• P0117 Engine Coolant Temperature Circuit Low Input
• P0118 Engine Coolant Temperature Circuit High Input
• P0119 Engine Coolant Temperature Circuit Intermittent
• P0120 Throttle Position Sensor/Switch A Circuit Malfunction
• P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
• P0122 Throttle Position Sensor/Switch A Circuit Low Input
• P0123 Throttle Position Sensor/Switch A Circuit High Input
• P0124 Throttle Position Sensor/Switch A Circuit Intermittent
• P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
• P0126 Insufficient Coolant Temperature for Stable Operation
• P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
• P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
• P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
• P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
• P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
• P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
• P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
• P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
• P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
• P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
• P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
• P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
• P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
• P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
• P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
• P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
• P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
• P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
• P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
• P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
• P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
• P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
• P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
• P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
• P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
• P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
• P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
• P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
• P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
• P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
• P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
• P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
• P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
• P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
• P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
• P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
• P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
• P0170 Fuel Trim Malfunction (Bank 1)
• P0171 System too Lean (Bank 1)
• P0172 System too Rich (Bank 1)
• P0173 Fuel Trim Malfunction (Bank 2)
• P0174 System too Lean (Bank 2)
• P0175 System too Rich (Bank 2)
• P0176 Fuel Composition Sensor Circuit Malfunction
• P0177 Fuel Composition Sensor Circuit Range/Performance
• P0178 Fuel Composition Sensor Circuit Low Input
• P0179 Fuel Composition Sensor Circuit High Input
• P0180 Fuel Temperature Sensor A Circuit Malfunction
• P0181 Fuel Temperature Sensor A Circuit Range/Performance
• P0182 Fuel Temperature Sensor A Circuit Low Input
• P0183 Fuel Temperature Sensor A Circuit High Input
• P0184 Fuel Temperature Sensor A Circuit Intermittent
• P0185 Fuel Temperature Sensor B Circuit Malfunction
• P0186 Fuel Temperature Sensor B Circuit Range/Performance
• P0187 Fuel Temperature Sensor B Circuit Low Input
• P0188 Fuel Temperature Sensor B Circuit High Input
• P0189 Fuel Temperature Sensor B Circuit Intermittent
• P0190 Fuel Rail Pressure Sensor Circuit Malfunction
• P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
• P0192 Fuel Rail Pressure Sensor Circuit Low Input
• P0193 Fuel Rail Pressure Sensor Circuit High Input
• P0194 Fuel Rail Pressure Sensor Circuit Intermittent
• P0195 Engine Oil Temperature Sensor Malfunction
• P0196 Engine Oil Temperature Sensor Range/Performance
• P0197 Engine Oil Temperature Sensor Low
• P0198 Engine Oil Temperature Sensor High
• P0199 Engine Oil Temperature Sensor Intermittent
• P0200 Injector Circuit Malfunction
• P0201 Injector Circuit Malfunction - Cylinder 1
• P0202 Injector Circuit Malfunction - Cylinder 2
• P0203 Injector Circuit Malfunction - Cylinder 3
• P0204 Injector Circuit Malfunction - Cylinder 4
• P0205 Injector Circuit Malfunction - Cylinder 5
• P0206 Injector Circuit Malfunction - Cylinder 6
• P0207 Injector Circuit Malfunction - Cylinder 7
• P0208 Injector Circuit Malfunction - Cylinder 8
• P0209 Injector Circuit Malfunction - Cylinder 9
• P0210 Injector Circuit Malfunction - Cylinder 10
• P0211 Injector Circuit Malfunction - Cylinder 11
• P0212 Injector Circuit Malfunction - Cylinder 12
• P0213 Cold Start Injector 1 Malfunction
• P0214 Cold Start Injector 2 Malfunction
• P0215 Engine Shutoff Solenoid Malfunction
• P0216 Injection Timing Control Circuit Malfunction
• P0217 Engine Overtemp Condition
• P0218 Transmission Over Temperature Condition
• P0219 Engine Overspeed Condition
• P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
• P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
• P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
• P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
• P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
• P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
• P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
• P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
• P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
• P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
• P0230 Fuel Pump Primary Circuit Malfunction
• P0231 Fuel Pump Secondary Circuit Low
• P0232 Fuel Pump Secondary Circuit High
• P0233 Fuel Pump Secondary Circuit Intermittent
• P0251 Injection Pump Fuel Metering Control “A” Malfunction (Cam/Rotor/Injector)
• P0252 Injection Pump Fuel Metering Control “A” Range/Performance (Cam/Rotor/Injector)
• P0253 Injection Pump Fuel Metering Control “A” Low (Cam/Rotor/Injector)
• P0254 Injection Pump Fuel Metering Control “A” High (Cam/Rotor/Injector)
• P0255 Injection Pump Fuel Metering Control “A” Intermittent (Cam/Rotor/Injector)
• P0256 Injection Pump Fuel Metering Control “B” Malfunction (Cam/Rotor/Injector)
• P0257 Injection Pump Fuel Metering Control “B” Range/Performance Injector)
• P0258 Injection Pump Fuel Metering Control “B” Low (Cam/R
• P0259 Injection Pump Fuel Metering Control “B” High (Cam/R
• P0260 Injection Pump Fuel Metering Control “B” Intermittent Injector)
• P0261 Cylinder I Injector Circuit Low
• P0262 Cylinder I Injector Circuit High
• P0263 Cylinder I Contribution/Balance Fault
• P0264 Cylinder 2 Injector Circuit Low
• P0265 Cylinder 2 Injector Circuit High
• P0266 Cylinder 2 Contribution/Balance Fault
• P0267 Cylinder 3 Injector Circuit Low
• P0268 Cylinder 3 Injector Circuit High
• P0269 Cylinder 3 Contribution/Balance Fault
• P0270 Cylinder 4 Injector Circuit Low
• P0271 Cylinder 4 Injector Circuit High
• P0272 Cylinder 4 Contribution/Balance Fault
• P0273 Cylinder 5 Injector Circuit Low
• P0274 Cylinder 5 Injector Circuit High
• P0275 Cylinder S Contribution/Balance Fault
• P0276 Cylinder 6 Injector Circuit Low
• P0277 Cylinder 6 Injector Circuit High
• P0278 Cylinder 6 Contribution/Balance Fault
• P0279 Cylinder 7 Injector Circuit Low
• P0280 Cylinder 7 Injector Circuit High
• P0281 Cylinder 7 Contribution/Balance Fault
• P0298 Engine Oil Over Temperature Condition
• P0300 Random/Multiple Cylinder Misfire Detected
• P0301 Cylinder 1 Misfire Detected
• P0302 Cylinder 2 Misfire Detected
• P0303 Cylinder 3 Misfire Detected
• P0304 Cylinder 4 Misfire Detected
• P0305 Cylinder 5 Misfire Detected
• P0306 Cylinder 6 Misfire Detected
• P0307 Cylinder 7 Misfire Detected
• P0308 Cylinder 8 Misfire Detected
• P0313 Misfire Detected with Low Fuel
• P0314 Single Cylinder Misfire (Cylinder not Specified)
• P0315 Crankshaft Position System Variation Not Learned
• P0316 Misfire Detected On Startup (First 1000 Revolutions)
• P0317 Rough Road Hardware Not Present
• P0318 Rough Road Sensor A Signal Circuit
• P0319 Rough Road Sensor B Signal Circuit
• P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
• P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
• P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
• P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
• P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
• P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
• P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
• P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
• P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
• P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
• P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
• P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
• P0333 Knock Sensor 2 Circuit High Input (Bank 2)
• P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
• P0335 Crankshaft Position Sensor A Circuit Malfunction
• P0336 Crankshaft Position Sensor A Circuit Range/Performance
• P0337 Crankshaft Position Sensor A Circuit Low Input
• P0338 Crankshaft Position Sensor A Circuit High Input
• P0339 Crankshaft Position Sensor A Circuit Intermittent
• P0340 Camshaft Position Sensor Circuit Malfunction
• P0341 Camshaft Position Sensor Circuit Range/Performance
• P0342 Camshaft Position Sensor Circuit Low Input
• P0343 Camshaft Position Sensor Circuit High Input
• P0344 Camshaft Position Sensor Circuit Intermittent
• P0345 Camshaft Position Sensor A Circuit Malfunction (Bank 2)
• P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
• P0347 Camshaft Position Sensor A Circuit Low Input (Bank 2)
• P0348 Camshaft Position Sensor A Circuit High Input (Bank 2)
• P0349 Camshaft Position Sensor A Circuit Intermittent (Bank 2)
• P0350 Ignition Coil Primary/Secondary Circuit Malfunction
• P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
• P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
• P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
• P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
• P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
• P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
• P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
• P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
• P0370 Timing Reference High Resolution Signal A Malfunction
• P0371 Timing Reference High Resolution Signal A Too Many Pulses
• P0372 Timing Reference High Resolution Signal A Too Few Pulses
• P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
• P0374 Timing Reference High Resolution Signal A No Pulses
• P0375 Timing Reference High Resolution Signal B Malfunction
• P0376 Timing Reference High Resolution Signal B Too Many Pulses
• P0377 Timing Reference High Resolution Signal B Too Few Pulses
• P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
• P0379 Timing Reference High Resolution Signal B No Pulses
• P0380 Glow Plug/Heater Circuit “A” Malfunction
• P0381 Glow Plug/Heater Indicator Circuit Malfunction
• P0382 Exhaust Gas Recirculation Flow Malfunction
• P0385 Crankshaft Position Sensor B Circuit Malfunction
• P0386 Crankshaft Position Sensor B Circuit Range/Performance
• P0387 Crankshaft Position Sensor B Circuit Low Input
• P0388 Crankshaft Position Sensor B Circuit High Input
• P0389 Crankshaft Position Sensor B Circuit Intermittent
• P0400 Exhaust Gas Recirculation Flow Malfunction
• P0401 Exhaust Gas Recirculation Flow Insufficient Detected
• P0402 Exhaust Gas Recirculation Flow Excessive Detected
• P0403 Exhaust Gas Recirculation Circuit Malfunction
• P0404 Exhaust Gas Recirculation Circuit Range/Performance
• P0405 Exhaust Gas Recirculation Sensor A Circuit Low
• P0406 Exhaust Gas Recirculation Sensor A Circuit High
• P0407 Exhaust Gas Recirculation Sensor B Circuit Low
• P0408 Exhaust Gas Recirculation Sensor B Circuit High
• P0410 Secondary Air Injection System Malfunction
• P0411 Secondary Air Injection System Incorrect Flow Detected
• P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
• P0413 Secondary Air Injection System Switching Valve A Circuit Open
• P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
• P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
• P0416 Secondary Air Injection System Switching Valve B Circuit Open
• P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
• P0418 Secondary Air Injection System Relay “A” Circuit Malfunction
• P0419 Secondary Air Injection System Relay “B” Circuit Malfunction
• P0420 Catalyst System Efficiency Below Threshold (Bank 1)
• P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
• P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
• P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
• P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
• P0430 Catalyst System Efficiency Below Threshold (Bank 2)
• P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
• P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
• P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
• P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
• P0440 Evaporative Emission Control System Malfunction
• P0441 Evaporative Emission Control System Incorrect Purge Flow
• P0442 Evaporative Emission Control System Leak Detected (small leak)
• P0443 Evaporative Emission Control System Purge Control Valve Circuit
• P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
• P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
• P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
• P0447 Evaporative Emission Control System Vent Control Circuit Open
• P0448 Evaporative Emission Control System Vent Control Circuit Shorted
• P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
• P0450 Evaporative Emission Control System Pressure Sensor Malfunction
• P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
• P0452 Evaporative Emission Control System Pressure Sensor Low Input
• P0453 Evaporative Emission Control System Pressure Sensor High Input
• P0454 Evaporative Emission Control System Pressure Sensor Intermittent
• P0455 Evaporative Emission Control System Leak Detected (gross leak)
• P0456 Evaporative Emissions System Small Leak Detected
• P0457 Evaporative Emission Control System Leak Detected
• P0458 Evaporative Emission System Purge Control Valve Circuit Low
• P0459 Evaporative Emission System Purge Control Valve Circuit High
• P0460 Fuel Level Sensor Circuit Malfunction
• P0461 Fuel Level Sensor Circuit Range/Performance
• P0462 Fuel Level Sensor Circuit Low Input
• P0463 Fuel Level Sensor Circuit High Input
• P0464 Fuel Level Sensor Circuit Intermittent
• P0465 Purge Flow Sensor Circuit Malfunction
• P0466 Purge Flow Sensor Circuit Range/Performance
• P0467 Purge Flow Sensor Circuit Low Input
• P0468 Purge Flow Sensor Circuit High Input
• P0469 Purge Flow Sensor Circuit Intermittent
• P0470 Exhaust Pressure Sensor Malfunction
• P0471 Exhaust Pressure Sensor Range/Performance
• P0472 Exhaust Pressure Sensor Low
• P0473 Exhaust Pressure Sensor High
• P0474 Exhaust Pressure Sensor Intermittent
• P0475 Exhaust Pressure Control Valve Malfunction
• P0476 Exhaust Pressure Control Valve Range/Performance
• P0477 Exhaust Pressure Control Valve Low
• P0478 Exhaust Pressure Control Valve High
• P0479 Exhaust Pressure Control Valve Intermittent
• P0480 Cooling Fan I Control Circuit Malfunction
• P0481 Cooling Fan 2 Control Circuit Malfunction
• P0482 Cooling Fan 3 Control Circuit Malfunction
• P0483 Cooling Fan Rationality Check Malfunction
• P0484 Cooling Fan Circuit Over Current
• P0485 Cooling Fan Power/Ground Circuit Malfunction
• P0500 Vehicle Speed Sensor Malfunction
• P0501 Vehicle Speed Sensor Range/Performance
• P0502 Vehicle Speed Sensor Low Input
• P0503 Vehicle Speed Sensor Intermittent/Erratic/High
• P0505 Idle Control System Malfunction
• P0506 Idle Control System RPM Lower Than Expected
• P0507 Idle Control System RPM Higher Than Expected
• P0510 Closed Throttle Position Switch Malfunction
• P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
• P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
• P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
• P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
• P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
• P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
• P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
• P0533 A/C Refrigerant Pressure Sensor Circuit High Input
• P0534 Air Conditioner Refrigerant Charge Loss
• P0550 Power Steering Pressure Sensor Circuit Malfunction
• P0551 Power Steering Pressure Sensor Circuit Range/Performance
• P0552 Power Steering Pressure Sensor Circuit Low Input
• P0553 Power Steering Pressure Sensor Circuit High Input
• P0554 Power Steering Pressure Sensor Circuit Intermittent
• P0560 System Voltage Malfunction
• P0561 System Voltage Unstable
• P0562 System Voltage Low
• P0563 System Voltage High
• P0565 Cruise Control On Signal Malfunction
• P0566 Cruise Control Off Signal Malfunction
• P0567 Cruise Control Resume Signal Malfunction
• P0568 Cruise Control Set Signal Malfunction
• P0569 Cruise Control Coast Signal Malfunction
• P0570 Cruise Control Accel Signal Malfunction
• P0571 Cruise Control/Brake Switch A Circuit Malfunction
• P0572 Cruise Control/Brake Switch A Circuit Low
• P0573 Cruise Control/Brake Switch A Circuit High
• P0574 Cruise Control Related Malfunction
• P0575 Cruise Control Related Malfunction
• P0576 Cruise Control Related Malfunction
• P0578 Cruise Control Related Malfunction
• P0579 Cruise Control Related Malfunction
• P0580 Cruise Control Related Malfunction
• P0600 Serial Communication Link Malfunction
• P0601 Internal Control Module Memory Check Sum Error
• P0602 Control Module Programming Error
• P0603 Internal Control Module Keep Alive Memory (KAM) Error
• P0604 Internal Control Module Random Access Memory (RAM) Error
• P0605 Internal Control Module Read Only Memory (ROM) Error
• P0606 PCM Processor Fault
• P0607 Control Module Performance
• P0608 Control Module VSS Output “A” Malfunction
• P0609 Control Module VSS Output “B” Malfunction
• P0620 Generator Control Circuit Malfunction
• P0621 Generator Lamp “L” Control Circuit Malfunction
• P0622 Generator Field “F” Control Circuit Malfunction
• P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
• P0654 Engine RPM Output Circuit Malfunction
• P0655 Engine Hot Lamp Output Control Circuit Malfunction
• P0656 Fuel Level Output Circuit Malfunction
• P0700 Transmission Control System Malfunction
• P0701 Transmission Control System Range/Performance
• P0702 Transmission Control System Electrical
• P0703 Torque Converter/Brake Switch B Circuit Malfunction
• P0704 Clutch Switch Input Circuit Malfunction
• P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
• P0706 Transmission Range Sensor Circuit Range/Performance
• P0707 Transmission Range Sensor Circuit Low Input
• P0708 Transmission Range Sensor Circuit High Input
• P0709 Transmission Range Sensor Circuit Intermittent
• P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
• P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
• P0712 Transmission Fluid Temperature Sensor Circuit Low Input
• P0713 Transmission Fluid Temperature Sensor Circuit High Input
• P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
• P0715 Input/Turbine Speed Sensor Circuit Malfunction
• P0716 Input/Turbine Speed Sensor Circuit Range/Performance
• P0717 Input/Turbine Speed Sensor Circuit No Signal
• P0718 Input/Turbine Speed Sensor Circuit Intermittent
• P0719 Torque Converter/Brake Switch B Circuit Low
• P0720 Output Speed Sensor Circuit Malfunction
• P0721 Output Speed Sensor Range/Performance
• P0722 Output Speed Sensor No Signal
• P0723 Output Speed Sensor Intermittent
• P0724 Torque Converter/Brake Switch B Circuit High
• P0725 Engine Speed input Circuit Malfunction
• P0726 Engine Speed Input Circuit Range/Performance
• P0727 Engine Speed Input Circuit No Signal
• P0728 Engine Speed Input Circuit Intermittent
• P0730 Incorrect Gear Ratio
• P0731 Gear I Incorrect ratio
• P0732 Gear 2 Incorrect ratio
• P0733 Gear 3 Incorrect ratio
• P0734 Gear 4 Incorrect ratio
• P0735 Gear 5 Incorrect ratio
• P0736 Reverse incorrect gear ratio
• P0740 Torque Converter Clutch Circuit Malfunction
• P0741 Torque Converter Clutch Circuit Performance or Stuck Off
• P0742 Torque Converter Clutch Circuit Stock On
• P0743 Torque Converter Clutch Circuit Electrical
• P0744 Torque Converter Clutch Circuit Intermittent
• P0745 Pressure Control Solenoid Malfunction
• P0746 Pressure Control Solenoid Performance or Stuck Off
• P0747 Pressure Control Solenoid Stuck On
• P0748 Pressure Control Solenoid Electrical
• P0749 Pressure Control Solenoid Intermittent
• P0750 Shift Solenoid A Malfunction
• P0751 Shift Solenoid A Performance or Stuck Off
• P0752 Shift Solenoid A Stuck On
• P0753 Shift Solenoid A Electrical
• P0754 Shift Solenoid A Intermittent
• P0755 Shift Solenoid B Malfunction
• P0756 Shift Solenoid B Performance or Stock Off
• P0757 Shift Solenoid B Stuck On
• P0758 Shift Solenoid B Electrical
• P0759 Shift Solenoid B Intermittent
• P0760 Shift Solenoid C Malfunction
• P0761 Shift Solenoid C Performance or Stuck Off
• P0762 Shift Solenoid C Stuck On
• P0763 Shift Solenoid C Electrical
• P0764 Shift Solenoid C Intermittent
• P0765 Shift Solenoid D Malfunction
• P0766 Shift Solenoid D Performance or Stuck Off
• P0767 Shift Solenoid D Stuck On
• P0768 Shift Solenoid D Electrical
• P0769 Shift Solenoid D Intermittent
• P0770 Shift Solenoid E Malfunction
• P0771 Shift Solenoid E Performance or Stuck Off
• P0772 Shift Solenoid E Stuck On
• P0773 Shift Solenoid E Electrical
• P0774 Shift Solenoid E Intermittent
• P0780 Shift Malfunction
• P0781 1-2 Shift Malfunction
• P0782 2-3 Shift Malfunction
• P0783 3-4 Shift Malfunction
• P0784 4-5 Shift Malfunction
• P0785 Shift/Timing Solenoid Malfunction
• P0786 Shift/Timing Solenoid Range/Performance
• P0787 Shift/Timing Solenoid Low
• P0788 Shift/Timing Solenoid High
• P0789 Shift/Timing Solenoid Intermittent
• P0790 Normal/Performance Switch Circuit Malfunction
• P0801 Reverse Inhibit Control Circuit Malfunction
• P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
• P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
• CodeDescription
• P1100 BARO Sensor Circuit.
• P1120 Accelerator Pedal Position Sensor Circuit.
• P1121 Accelerator Pedal Position Sensor Range/Performance Problem.
• P1125 Throttle Control Motor Circuit.
• P1126 Magnetic Clutch Circuit.
• P1127 ETCS Actuator Power Source Circuit.
• P1128 Throttle Control Motor Lock.
• P1129 Electric Throttle Control System.
• P1130 Air/Fuel Sensor Circuit Range/Performance. (Bank 1 Sensor 1)
• P1133 Air/Fuel Sensor Circuit Response. (Bank 1 Sensor 1)
• P1135 Air/Fuel Sensor Heater Circuit Response. (Bank 1 Sensor 1)
• P1150 Air/Fuel Sensor Circuit Range/Performance. (Bank 1 Sensor 2)
• P1153 Air/Fuel Sensor Circuit Response. (Bank 1 Sensor 2)
• P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
• P1200 Fuel Pump Relay Circuit.
• P1300 Igniter Circuit Malfunction - No. 1.
• P1310 Igniter Circuit Malfunction - No. 2.
• P1335 No Crankshaft Position Sensor Signal - Engine Running.
• P1349 VVT System.
• P1400 Sub-Throttle Position Sensor.
• P1401 Sub-Throttle Position Sensor Range/Performance Problem.
• P1411 EGR Valve Position Sensor Circuit Range/Performance.
• P1500 Starter Signal Circuit.
• P1520 Stop Lamp Switch Signal Malfunction.
• P1565 Cruise Control Main Switch Circuit.
• P1600 ECM BATT Malfunction
• P1605 Knock Control CPU.
• P1630 Traction Control System.
• P1633 ECM.
• P1652 Idle Air Control Valve Control Circuit.
• P1656 OCV Circuit.
• P1661 EGR Circuit.
• P1662 EGR by-pass Valve Control Circuit.
• P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
And there are more. Believe us now Jeff?
