My nephew replaced my spark plugs last night. I drove the car a short distance today and home. I got in tonight and there was oil all over my driveway. I did not hear any pop or loud noise Do you have any idea what could have happened?
Fluid leaks are usually the quietest type of auto failure there is. Someone will need to open the hood, check the fluid levels and assess the spill to determine what is leaking. There are coolant pipes to the heater core running across the engine that could have been disturbed during the spark plug replacement.
If you can’t check the fluid levels or identify the leak it would be best to have the vehicle towed to a repair shop.
