2002 Honda Accord Sdn - Shakes
If I have bad motor mounts will I be able to feel the shaking through the wheel are the whole car in its self
The whole car. Most times it’s worse on acceleration.
Describe the problem. When does the car shake? Is it at a certain speed range? Is it worse when accelerating or braking? Do you feel it in the whole body, the brake pedal, or the steering wheel? What else can you tell us about the shake?
Both the steering wheel and the entire vehicle can shake with bad mounts. Which shakes more, just depends on the situation.
