Oil pressure gauge jumps around after warmed up Have replaced sending unit and gauge
For about 30 years Ford oil pressure gauges have been phony. The sender is just an on-off switch that closes at about 12 psi and grounds the sensor circuit through a resistor which keeps the gauge reading about 50%. Of course Tester’s suggestion to test with a mechanical gauge is your best next step and if the pressure is constant and above 45psi cold you need to closely inspect the wiring harness and if no problem is found there the instrument cluster may have a glitch.
