2001 saab 9-3 starting problem
My wife’s Saab intermittently will not start. This typically happens after a short trip. When turning the key, all battery functions are fine and there is a clicking sound under the hood (but no engine turnover). If the car sits for 10-30 mins it will start again.
This problem typically happens in spurts - two to three times a week or even twice in a day - and then she can go months without experiencing it.
It’s been suggested that the crankshaft position sensor might be the culprit - but the diagnostic run by the mechanic showed no history in the ‘black box’ of any error. I’ve also read that the neutral position switch could play a role.
We need help.
willyffej
Any luck I have same problem with same car?
