I had my Honda Odyssey transmission replaced 2 years ago. The past few months, in the first mile that I drive the car on streets in our neighborhood, the car goes into high RPMs (about 3000) before it seems to drop into gear. It does this 2 or 3 times then works fine after that. The “Check engine” light is now on all the time. Sometimes, the car does one other weird thing–the high RPMs end with the drive/D4 light flashing on and off like a blinker (even if I change gears to D3. When this happens, if I turn the ignition off it comes back on and seems to function fine.
I have had it back to the shop that did the work about 4-5 times to get it right. I like the guys but each time they return it to me, the problem remains. I took a 2000 mile trip with it and with the exception of this persistent problem, the van worked fine.
Any idea what is going on?
