My wife and I recently purchased a 2001 Grand Caravan Sport. The first month it was great, but recently the power steering has been really really loud. We figured it was the power steering fluid. So I went to check it and I cant find where to put the fluid in anywhere under the hood. I’m partially blind so it would be great if someone could tell me where its located so I could attempt to fix this problem. Again thanks for the help.
You Will Need An Owner’s Manual For This Vehicle. The Manual Should Have This Information.
CSA
The (counting) 5 or 6 service points should all be marked with YELLOW. Oil, coolant, PS, Brake fluid, trans fluid, washer solvent. All YELLOW. The oil/trans dipstick(s) should also have a yellow handle.
On 2001 Grand Caravans with the larger V6, it’s to the right of the plenum up near the fire wall. Here it’s down and to the right of the scissors.
