my caravan will turn over but will not catch I had the fuel pump,alternator checked they were fine please help
Which engine do you have?
Was the fuel pressure checked? Is fuel getting to the injectors?
When was the fuel filter last changed?
Have you pulled a spark plug out and lain it on the manifold and cranked the engine to check for spark?
Spray a little starting fluid in the throttle body (or remove the air filter and spray) and crank the engine over.
If it starts then dies you will know you have a fuel supply problem.
Check for spark first.
not catch WHAT?
Check to see if there is spark getting to the plugs.
NOT CATCH? WHAT?
more info? PLEASE.
engine size?
trans
