Checked trans fluid, looks overfilled, at times does not shift properly
How did it get over-filled? Did you do it? Did a shop do it? Or has it mysteriously started to overfill. The last one likely means your transmission cooler in the radiator has failed and is allowing coolant (water) to enter your transmission. That will kill it very quickly! You need to have that checked out ASAP!
