My name is Steven
I am the proud owner of a P.O.S it’s a 2001 Chevrolet Malibu, the trouble is with my ABS braking system. I replaced both hubs a year ago they have the ABS sensor built into them. The light has started coming on so I checked the voltage on both sides of the car the reading are, driverside at 169mv-320mv and the ohm reading is 1.02K, on the passenger side it reads 140mv-240mv the ohm reads 1.01K, one is a bit lower but well above the 50mv minimum. When I restart my car sometimes the light is out until the ABS kicks in on a wet or gravel road. Then the dash light comes on and the ABS system shuts down again, the only thing a code reader states is low voltage in the system but does not call out what side or where the low voltage is coming from… any suggestion?
Thanks for your time.
steven
