On my 2006 Camry, my ABS comes on intermittently when braking (~5% of the time) and the speed is very slow (5 mph or less). Exact speed is hard to say. I think one of the ABS sensors is misreading. No ABS fault light on dash.
I have an explanation of how to check the sensors for AC voltage when spinning the wheel using a DVM.
- Without a lift can I check this under the hood instead of at the wheel? Possibly at the plug into the ABS module.
- Someone else on another thread mentioned that their dealership hooked in a monitor and drove around. When I asked my dealership how they would diagnose this, they said they would do the same check as I mentioned above (#1). This would be expensive and since it is intermittent, they might not see anything. Does anyone know if this monitor exists and what it is called?
