I recently purchased a 200 Toyota Land Cruiser. The right rear power quarter window does not work (will not open). The left side works fine. When I use the right window switch there is no noise or function.
Does anyone have a suggestion?
Broken or loose/corroded wiring/connections or perhaps a burned out window motor.
Check the wiring to the switch too.
Are these switches on the dash or drivers door arm rest?
