I have the equipment to check the codes - where does it plug in?
Usually under the dash board between the drivers door and the steering wheel.
The owner’s manual may tell you where the plug is located.
Sometimes, there’s a black rubber cap on the connector which obscures the connector. Look for it on the bottom edge of the dash, near the steering column.
