Hi everyone, I have been researching this issue for a while, but haven’t found a solution. Though I did find a thread somewhere else with the exact same symptoms, but no post saying what the solution was. I would be SO grateful if anyone can provide some good advice on this.
Here’s what is going on with my 2000 Dakota V6 3.9L V6:
After sitting for at least a couple of hours, the truck will crank but not start. After 3-5 tries, the truck does start but idles roughly at a very low RPM for 10 seconds or so and then stalls. I turn the key one more time and it starts up great and idles and drives normally. This behavior is very consistent. I have only driven it about 5 miles after it started doing this, because on that trip, the engine stalled while I was driving. Occasionally the MIL comes on and gives P0443 as the code. Question is, can the evap purge solenoid cause this behavior if it is going bad? I have inspected the vacuum lines, and they seem ok.
One more note: When this first started, I was pretty sure it was the fuel pump. Replacing that has not fixed the problem, and the fuel pump relay is good.
Thanks in advance!
