while at stop in netural, reve engine, it seems to want to stall after it hits higher rpm?
The engine management system has a rev limiter programmed into it. So if you’re in neutral and then try to rev the engine, it will only rev to a certain point then the rev limiter prevents the engine from over-reving.
