a/c blower not working.a/c condencer working & fuses are ok.bmw tech said I need blower replacement $1500.What else can I check for to try & fix
I believe you mean the condensor fan is working as the condensor would have to fail some pretty obvious visual inspections to recieve a “not working” lable.
In any case I have replaced several blower motors in this model. The job is not for the inexperienced or for ths “ham-fisted”. This job requires a delicate touch and a tech with a good memory and a lot of patience. Not a lot I can think of to soften this up as I believe the tech has used proper diagnostic procedure in calling the blower motor the problem (unless you provide info. to the contrary).
