1999 toy camry 2.2 5sfe - non interference engine?
I am first time rebuilding my engine. All is well, right at the end but no start. Crank, yes. but no start. With engine installed, I can’t see the camshaft timing mark due to the engine mount bracket. Still when the motor was out, it was just sraight up parallel with the piston stroke right? Right? It cranks and goes chug chug chug plunk, chug chug chug plunk,
This IS a non-interference engine
Do you have good compression?
If not, perhaps your marks are off . . . ?
@cdaquila
Can we merge both of this guy’s discussions into one?
They’re both clearly about engine problems on his 1999 Camry with the 5S-FE engine
You are right, merge on
I have done some work on engines with longer firing orders so I thought that my 1999 Toyota CamryLE 2.2 5SFE would be a nice diversion. I sent out the block and head and they shop ordered parts. I have a full set of original Toyota manuals for the vehicle. The engine has been reinstalled and it will not start. It goes chug chug chug plunk… chug chug chug plunk…I figure that the timing is off. Both marks are a lovely straight up. Crank pully indicates “0” degrees on the lower timing belt cover. When the engine was out, I could look through the hole in the camshaft pulley and see that mark also. Being ignorant, after several efforts, I bought a new timing belt. tension pully(s) and springs in a complete NAPA kit. It came with two springs and the second one certainly provided a better tension on the timing belt itself. Could it be a sensor? so many connections, so many connections…thanx.
Before I pull the valve cover off to verify canshaft timing is correct, Can you tell me, to align the two camshaft gears, one gear has two marks and one gear has one that meshes in between the two marks, right?
It’s been merged, @db4690
There are several videos on utube about replacing the timing belt on that engine .
