Last Fall the van had to be jumped when the temperature dropped into the low 40’s. Four batteries, a starter, a cam sensor, a crank sensor, an alternator and a flywheel later I’m faced with the same problem. Also, the van started fine this past Spring/Summer. What can be causing the lack of current to turn the engine over.
Well, I will start from scratch. Test battery and then alternator. New parts can be defective too. If all checks out okay then I will look for parasitic drain.
Today the mechanic is looking for a wiring problem between battery and starter.
Here is a no-start check-list for your mechanic to follow to fix your van: http://www.samarins.com/diagnose/index.html
