car jerks when changing gear and accelerating
Meh, you know the problem. Chances are you will not reply if we were to ask questions or made suggestions.
Is the check engine light on? Some owners have had similar symptoms from bad EGR vacuum lines. Might be worth investigating.
five-speed manual or four-speed automatic transmission?
