1998 Sunfire Horn relay location
I have to replace the horn relay in my 1998 Pontiac Sunfire but I can not find the location of it. The owners manual does not point out where it is and it is not in with the other relays under the hood. I also checked the Haynes manual and it too did not point me to the location. Any help would be greatly appriecated!
The relay is located in the fuse/relay panel located on the right side of the dash, behind the glovebox.
Do I have to remove the glovebox to see it? There is a fuse panel on the driver side of the dash but I do not think that is what you mean as the new relay from the auto parts store doesn’t fit in it.
Yes. Remove the glovebox.
Thank you very much as I would have never found it!!
Leo
