1997 Lesabre
trying to replace heater core on my 97 lesabre. How do you get the hose clamps off?
This tool will reach and remove the hose clamps.
https://www.autozone.com/wrenches-pliers-and-cutters/hose-clamp-pliers/oem-hose-clamp-pliers/607069_0_0
Another trick is to use a small worm clamp placed over the tangs of the spring clamp, and tighten the worm clamp to squeeze tangs together on the spring clamp.
Sometimes I use a tool as @Tester posted…sometimes a regular pliers, or a slip joint pliers.
But the one that @Tester showed works great at the hard to reach ones.
Yosemite
