Coolant leak front of engine from top right side. Unable to see where the fluid is coming from…
You have a few options, you could take it to a mechanic for diagnostics and repair, you could (when the engine is COLD) make sure the radiator and overflow are full, then rent a cooling system pressure test kit to see if it holds pressure (and if not where it is leaking from), you could also (again after making sure the system is full while the engine is COLD) add UV dye, drive it around, then use a black light to see where the leaking is coming from
