Dome light stays on with key on(while driving) or key off. Radio shuts off when key is turned off without opening the doors. All other interior lights seem to be properly working. (i.e. floor & map shut off after a few seconds) Interior light switch on dash seems to be working properly.
If you already checked the dome light switch on the dimmer control to make sure it isn’t on then the switch may be bad.
