Car starts great every time, and continues to run if held in the “start” position (No, I do not hold it in the “crank” position, so the starter is not running.)
It cuts out as soon as the key is released and rotates to “run.”
Could this possibly be the “ignition:module”? I ask because the ignition module is a known lemon part in the 1997 Acura TL2.5?
Is the only explanation the “ignition switch?”
Thanks
As stated in the other thread: It’s more than likely the ignition switch. It’s less than $75 bucks aftermarket. And not rocket science to install, either.
Read this: http://www.visualimpressions.ca/switch/
