Intermittent wipers don’t respond, otherwise the wipers work fine. While wipers are on full, if you back up to intermittent, the wipers stop at whatever location they happen to be in. They function and park fine at full speed. I wasn’t sure if there is a relay for this or if a replacement motor will resolve the issue - - Thanks
Can the board be replaced or will a new motor have one mounted?
Not sure, but personally I’d replace the whole wiper motor if the board is part of the motor. It’s going on 30 years old, not going to work any better. Might as well replace the whole thing.
I’ve got it now - - THANKS!
Mark, I’m going to suggest something different. I owned a 1999 Chevy Monte Carlo. Probably the same wiper control as yours. I had a problem with the control itself failing and causing intermittent wiper problems. Off, low and high worked fine. The intermittent function wouldn’t work correctly. This is the stalk on the right side of the steering column. A little easier to get to than the wiper motor.
