Geo won’t start. It has a new battery and air filter. Just replaced the fuel pump and fuel filter. I don’t hear the fuel pump “whirring” when I put the key in the ignition (to on position). All the dashboard lights come on when the car is in on position.
I suspect the relay or the fuse, but having trouble finding the correct one of each. What does the relay look like? i.e. part number? What is the spec for the fuse? 20amp 30 amp???
Any suggestions would be great. This has been a great car.
OP states he doesn’t hear the fuel pump whirring when the key is turned to the on position, if this is normal behavior of the car this verifies an electric fuel pump.
