Need advice on a fuel leak
The leak is above the starter. I removed the starter but now can’t start it to see where it’s coming from
If it’s clear fuel…Keep looking…UP…till you find a source of fuel.
Clean off the engine and intake area so you’ll be able to see the leak re-start.
Probably from one of the fuel fittings at the rear of that right cylinder head.
