Where is the flasher located on the 1995 Buick Century? It needs to be replaced but unable to locate it.
It appears both flashers are behind the glove box door.
edb1961, your link goes to info for a 2007 Expedition! Oops. I believe on your Century, they are tucked away behind the dashboard on the driver’s side. You can get to them by contorting your body at strange angles while laying on the driver’s side floorboard. If the flasher still works, you can allow it to operate and follow the noise. Another thing to keep in mind is that your car has two of them, so you want to be sure to replace the bad one. They are normally close to each other, so if your turn signals don’t flash, but the hazards do, turn on the hazards, follow the noise, leave that one alone, and look for another one nearby.
Checked and it was not located in behind teh glove box door. Thanks for the information though
