I have a f150 ford pickup 1994 air bag light stays on once I start it. truck will not pass inspection one mechanic replaced clock spring. others do not know what to do. please help
Ok, the clock spring has been replaced. Replacing the clock spring was a “guess” and not an actual diagnosis.
Apparently other parts need to be replaced. Maybe wiring. You need to find a better mechanic. Sorry, I can’t tell you what to fix over the internet or it will be just the same as the clock spring “guess.” Good Luck.
