Engine stop when driving restraded by pumping pedal then stop again and would not start
Remove a spark plug wire from one of the spark plugs, and plug a spare spark plug into the wire and lay the spark plug on the engine.
Now have someone crank the engine over while watching the spark plug.
If there’s no spark at the tip of the spark plug, the ignition control module has probably failed.
https://www.rockauto.com/en/moreinfo.php?pk=5434788&cc=1414572&jsn=476
