Thursday my S10 just stopped running. When I tired to start it, it just keeps turning over. I changed the $144 ignition module and that’s not the prob cause it still does the same thing. Any suggestions?
Check for spark…if spark, check for fuel.
I have done both. Now, people are telling me it may be the crank sensor. What say you?
Is it turning over fast if so it may be the timing belt or chain!!!
Would not having a spark at the plug/spark plug wire be caused by a bad timing belt/chain?
Could be a crank sensor.
Is this a 4 cylinder?
The engine just turns over and over. If it were an earlier model I would have already checked the distributor cap and rotor. It just died on me while I was driving it and now won’t start.
Yes, it’s a 2 wheel drive, 4 cylinder 2.2 engine
It still sounds like the timing chain/belt,im not sure if it has anything to do with spark~~!!
